Hi all.
I am installing DT managed with 3 nodes, and to connect to the client’s network I do it through a Pulse Secure web portal. And I have had a problem, when accessing the URL of the cluster and logging in, the page does not load.
I think the PULSE is acting as a proxy and replaces part of the URL string
Has anyone solved something like this? Would I have to touch the nginx configuration?
thanks in advanced.
Jose A
No matter what Proxy/LB/VPN is used … you have to ensure that this is rewriting all requests as they are to reach to Dynatrace Manged nodes.
Check Pulse configuration if it’s doing so. Request should end at
https://<your-cluster-hostname>:443
thank you @Radoslaw S.
dumb doubt…
https://my-cluster-hostname:443
may be like
https://mlv569.dynatrace-managed.com:443
This is the configuration:
but it does not work..
Can anyone help us with this configuration?
I have no knowledge of PULSE
Maybe it’s proper. It’s anyway controlling just the access to the server. You still need to have a network connection between Pulse and Dynatrace Managed.
What specifically is loading? Can you check in the browser if you wait for Pulse response or Dynatrace Managed?
This is the browser log. I don’t understand the answers, can you help me?
Thank you
Indeed looks like something is there in between that blocks connection. Don’t know how can I further help you, sorry. If I were you I’d contact with Pulse so they can help you set this up.
Thank you very much for your help.
best regard
Jose A
