So for 8.9k devices, I would recommend configuring at least a 10-minute data collection interval.
(You may see ~+20s monitor execution times in the error log because the extension internally drops queries once the configured interval is exceeded.)
Please note that scaling estimates must be based on the real number of devices in the monitored system.
Filters configured in the extension are applied only after all device and interface data has already been polled (due to REST API limitations).
Support has increase the interface limit now. Unfortunately that didn’t help us enough, we are still not seeing reliable data. I assume our network I simply to large, queries take too long (I’m at 15min interval now). I tried using multiple configurations for different devices types to increase the parallelism.. that did very little.
Biggest issue remains, the interfaces which are not always showing up. Also with a 15min interval I can’t use this for actual monitoring.
What is VERY convenient that I can “import” all the devices from the Catalyst center. That something that has a lot of potential for us. I couldn’t achieve this via the SNMP extension, there are simly too many networks and IP ranges (requires hundreds of configs.. no way).
I’m trying to solve two problems:
1. Get our network devices into dynatrace. Catalyst center is the single source of truth for our network devices. If it’s running somewhere in our network, it’s configured via the CC. (8.8k devices, 200k+ interfaces, global network spanning 350 sites).
2. Monitor the most important devices. These would include devices installed in datacenters or the core infrastructure of a site.
I guess what I’m looking for would be a combination of both extensions:
- catalyst center integration is a perfect way to get the up2date list of devices
- snmp/cisco extension allows capturing the timeseries for devices, however I can’t"reuse" the device list provided by the catalyst center right now.
You can configure the Cisco Catalyst Center (DNA) extension to use an older API version. Even if you are running version 2.3.7.9, you can specify an earlier API version (for example, 2.3.5.3 – prior to 2.3.7.6) in the extension configuration.
In this case, the extension will not collect detailed interface statistics from Catalyst Center and report related metrics. Only the administrative and operational status will be reported as metrics. Interface entities will still be created, but no detailed interface metrics will be collected.
By doing this, you may be able to decrease the data collection interval, as the extension will no longer execute 200+ paginated data queries.
The Cisco Catalyst Center (DNA) extension and, for example, the Generic Cisco Device extension (which uses SNMP to feed Dynatrace with metrics and alerts) both follow the concept described here: https://docs.dynatrace.com/docs/shortlink/network-topology
Both extensions create entities of type dt.entity.network:device and establish a same_as relationship between their extension-specific device entities (such as dt.entity.cisco_cc:device and dt.entity.snmp:com_dynatrace_extension_snmp_generic_device) and the generic network device entities.
By leveraging these relationships, I believe you should be able to “reuse” the device list provided by Cisco Catalyst Center and metrics provided by SNMP based extension.
Please review the attached images showing the generic network device entity in the Infrastructure & Operations application, along with its entity relationships.
I am aware of the generic network devices and the cisco devices. The problem I am facing is getting them configured in a convenient way. We got 8.8k such devices, using IP ranges I would still require ~3500 configurations for those extensions. Those ranges are also subject to changes, that happens rather frequently. Maintaining an accurate list is therfore rather labour intense and that’s impossible to maintain.
The Catalyst Center however got the accurate list at all times. I could use those devices to create configurations for all the devices via API, but I would still end up with a 4 digit long list of configurations.. extremely inconvenient to maintain.
My thoughts were: get the devices from the Catalyst Center, then query them via the cisco extension, but without configurating them all separately. Other extensions provide options to configure something for a host, hostgroup, management zone, tags, whole environment.. what I am looking for is something like:
- “get devices from Catalyst Center” for the generic / cisco extension
- in the catalyst extension a convenient way to “hand over” to the cisco extension
Thank you for the feedback. We appreciate it. I’ve discussed it with @MartinMarko, and we think this could be doable by the following approach already:
Cisco DNA extension already propagates the Smartscape with Cisco device entities and their Site IDs and other metadata.
I assume you have a set of ActiveGates which can poll the nearest SNMP devices using the Generic SNMP extension (one AG group can probably poll multiple defined sites).
Have a lookup table defined in Dynatrace to look up ActiveGate group by the Cisco Site ID (so you can actively control which AG group will be used) - that’s the only “manual” configuration you need to maintain and will be mostly static unless you configure new sites or firewall clearances change
Define a Dynatrace workflow which will run maybe once a day and will:
Get the Cisco device entities and metadata from Smartscape populated by Cisco DNA extension. If there is any data missing in the entities, we can add it to the DNA extension and populate it.
Lookup the ActiveGate groups by the Site IDs for those devices.
Add or update Generic SNMP Extension configurations to poll the metrics using the Settings API.
This will basically automate the configuration of the Generic SNMP extension for Cisco devices known to Cisco DNA.
We will be happy to assist you with prototyping this solution. What needs to be double-checked is the number of configurations. You can still have up to 20k devices per Generic SNMP extension configuration or Generic Cisco extension. How many configurations do you need ? This would be determined by the number of ActiveGate groups being able to poll sites. You have 350 sites. How many ActiveGate groups do you have? Is this one ActiveGate group per site?
Right now the devices are configured in 3.3k sites inside the catalyst center. To this point we didn’t need many AG groups, we are only running 3 right now. They are currently setup in central locations in our infrastructure (on prem datacenter, Azure and AWS, currently all in europe), so they are independed from our corporations locations. These groups can be easily expanded or more groups added if latency / bandwidth become a problem.
I assume that adding some AG groups in the right places in our network (eg. in the US, in Brazil, Asia and Australia) would be sufficient.
I need to doublecheck your approch with the network team. They got the 8.8k devices organised into 3.3k sites in the catalyst center. Typically multiple catalyst sites map to one actual location (IT and OT networks, guest networks, multiple WAN uplinks, multiple subnets…). Maintaining the lookup table would be their job, also the costs for the extra AGs would come out of their budget.
