How to integrate solarwinds network performance monitor with Dynatrace
If youâre asking about getting SolarWinds data into Dynatrace, I guess youâd have to query the SolarWinds API to pull the required info from there, then bring it into Dynatrace via the custom device API. Alternatively, youâd have to build an ActiveGate plugin.
I found a Solarwinds repository on Github, which might be of help. Thereâs a Python SDK available too, which is the development language used for Dynatrace OneAgent and ActiveGate plugins too ![]()
My company has several Dynatrace customers and all of them are also using Solarwinds for NPM. I developed an extension that will make a call to Solarwinds using their REST API and then parse the return devices and send time series and metadata about the devices as custom devices to Dynatrace using again, the REST API. If anyone is interested in using, Iâd be happy to share. Iâve attached a powerpoint slide deck of what it looks like when the extension is running. Dynatrace-Solarwinds-Extension.pptx
It was developed and runs on Linux (Red Hat based) using only the following.
â˘Job Scheduler (cron)
â˘BASH Shell environment
â˘The JSON processor called âjqâ
â˘Solarwinds NPM API endpoint w/service account username/password
â˘Dynatrace managed or SaaS tenant + API Token with Data Ingest access scope
As is it will publish the following time series metrics
- Status
- Response Time
- CPU Load
- Percent Memory Used
- Percent Network Loss
When an abnormal status is returned a problem event is published for the custom device. The slide deck should walk you through it.
Enjoy! I know I enjoyed writing it.
-Tommy Noonan
dynatrace-solarwinds-extension.pptx (832 KB)
HI @Siva P.
We came across solarwinds remote plugin custom.remote.python.solarwinds.zip
Donât remember if we tried it and if it works or not but it worth try it.
This is the endpoint configuration it expose
And here are the metric its collect
HTH
Yos
customremotepythonsolarwinds.zip (2.7 KB)
Had the SE that supported me and my organization only supplied that after repeated requests over months of timeâŚI might have saved a few hoursâŚappreciate you sharing. And it was still fun to develop. ![]()
I gave it a shot loading and after what is reported as a successful upload of the extension, I ultimately get âExtension doesnât exist on given hostâ on my environment activegate in our lab after configuring the extension to access our Solarwinds NPM system.
Very happy to have a close to working example however. If anyone has experienced this issue, I would love to know what you did to resolve.
Hi @Tommy N.
Did you unzip the the plugin to plugin_deployment directory under remotepluginmodule at the AG and restart the remote plugin process?
Yos
Hello! That helped us get a little further but now weâre at "Error(No module named âorionsdkâ). Iâve installed the orionsdk from GitHub via pip on the activegate⌠not sure what else to try.
Will try it with a customer and will update
Yos
HI @Tommy N.
I am interested in studying and trying out the code. I have encountered the requirement to correlate events on network devices and other OOTB components captured on Dynatrace. My immediate go-to is the DT SNMP plugin by @Brayden N. I will also consider integration to existing NPM tools such as SolarWinds.
Please let me know how I can access the extension.
Thank you.
Would you be able to share the plugin, would love to replicate the same functionality on our solarwinds instance
Here it goes: solarwinds.zip
solarwinds.zip (2.63 KB)
Hi Tommy,
Can you please share the extension that you developed for Solarwinds NPM?.
Thank you.
Michael.
Hi Michael, the extension is shared on this page twice already, see Yos N.'s comments (look for the .zip files) ![]()
Hey @Yos N.,
Have you been able to make it work? Weâre also going to try out this extension next week. It would be great to have your feedback about your progress.
I bet thereâs not a whole lot of customers out there trying to do this anymoreâŚ
