Hi Yos,
Thank you for the timely response. After adding the object it works 100%.
Hi Yos,
Hi Yos,
Do you perhaps know what the polling intervals are when querying solarwinds?
Andre
AG Plugin runs every minute as explained in documentation
HTH
Thank you for that info Yos
Sorry, can you share again, I get an 404 error. Thanks
Please share the extension file(zip) when i try it goes to 404 page not found error
@Yosi_Neuman. That extension is a paid extension from the Dynatrace services team. Please donât share it.
If anyone is interested in a pre built extension such as this one please reach out to your account or delivery manager and they can get in touch with our professional services team.
Mike
Roger that
Yos
Update :alarm:
It took some time but finally we got customer time and space to test this plugin and we succeeded to operate the it. The only thing that we need to do was to built the plugin (plugin_sdk build_plugin --no_upload) and then extracted the attach custom.remote.python.solarwinds.zip to C:\Program Files\dynatrace\remotepluginmodule\plugin_deployment, after that it works as a charm!!
HTH
Yos
custom.remote.python.solarwinds.zip (520 KB)
Where is this package? Since the Dynatrace web site new version, I canât find it and all the links in this post are no more responding.
I have a customer that is trying to use this extension to integrate their Dynatrace managed instance with SolarWinds, however I have a few questions if anyone can help me from the people that used it.
I have seen the metrics that this extension pulls already, however, my customer is under the impression that the routers/switches etc from SW, will be visible in DT Smartscape and that they will have full Observability, can anyone confirm this?
The data will not be linked in the Smartscape and wonât be part of the root cause of Davis. The best way to get observability is to configure Dynatrace extensions to poll information from your network infrastructure.
Which extension do you advise for such a requirement, I can see multiple ones for Cisco devices for example.
I know this an older post, but now with the updates to python extensions, will this extension need to be updated as well?
