I would keep the integration fairly simple. Since ServiceNow Event Management is event-based, I would send Dynatrace events into ServiceNow and let ServiceNow handle the processing afterwards, such as deduplication, CI binding, alert creation, assignment and incident creation.
I would not use Dynatrace Alerting Profiles to determine resolver groups or to replicate ServiceNow assignment logic. Doing so would quickly result in a large number of Alerting Profiles for individual applications or support teams, which becomes difficult to maintain and scale.
I would mainly use Alerting Profiles to determine which events or problems are relevant enough to be forwarded, and after what duration, in order to prevent over-alerting. For example, an availability issue might be forwarded immediately, while a slowdown or resource issue may only be forwarded after it has persisted for a certain amount of time.
For the actual severity, I would use the severity of the Dynatrace event as the starting point. Dynatrace now has a standardized event.severity model from 1 to 5: Critical, Major, Minor, Warning and Informational. A Problem inherits the highest severity of the events correlated into that Problem.
This is especially interesting for custom anomaly detectors, because you can explicitly set an event.severity on those events. This allows you to classify custom alerts consistently instead of relying only on their event type or category.
I would also avoid directly mapping Dynatrace severity to an assignment group. Severity tells you how serious the issue is, but not necessarily who is responsible for resolving it. The assignment group should ideally be determined based on the affected or root-cause CI, ownership information and CMDB relationships in ServiceNow.
So in short: use Alerting Profiles primarily to control what gets forwarded and when, in order to reduce noise. Use event.severity to consistently describe the technical severity of the event, including custom anomaly events. Then let ServiceNow Event Management handle CI binding, Event Management correlation/deduplication, ownership, assignment and incident creation.
This also prevents ending up with a large number of Alerting Profiles for every application or support team.
