Integration with Google App Engine (G.A.E) standard
Dynatrace supports an OneAgent installation on a Google App Engine (G.A.E) flexible environment.
However, it doesn’t for a G.A.E standard one.
We noticed that some G.A.E standard technologies do support some observability Frameworks (e.g.: OpenTelemetry for most languages, OpenCensus for PHP, …).
Does the Community have any interesting insight in gathering data from G.A.E standard using Dynatrace?
Namely, in the context of the above-mentioned observability frameworks ??
Thanks!
@PedroDeodato as you mentioned it is supported but there is no mention of G.A.E Standard One. https://www.dynatrace.com/support/help/setup-and-configuration/setup-on-cloud-platforms/google-cloud-platform/deploy-oneagent-for-google-app-engine-apps With Perform right around the corner maybe we will get more information on this.
Have you gotten any more insights into this that you could share with the community?
Hey, Chad,
That’s a negative: no insights yet :disappointed_face:
Hello @PedroDeodato for App Engine Standard, the way to deploy Dynatrace is with OneAgent for PaaS applications, I recently test it and it worked for a node.js application running on App Engine Standard, following this process:
This way you’ll get insights at the service level (traces). You may also get more metrics for app engine doing the Google Account Integration:
