Can anyone help with integrating Jenkins into Dynatrace? I just found some information from the AppMon era
Hey ArtuD, how are you looking to integrate? What is the end goal? If you provide some more information then hopefully someone who has done what you’re looking to do can provide more specific help.
Otherwise here are the docs for a couple of the more common integrations you could do:
- Release validation, allows you to improve the quality of releases from both a performance/stability point of view as well as from a security point of view. These docs also have jenkins specific examples: Set up automated release validation with Site Reliability Guardian — Dynatrace Docs
- Release monitoring, allows you to attach additional metadata related to releases to entities providing additional context for root cause analysis: https://docs.dynatrace.com/docs/platform-modules/automations/release-monitoring/version-detection-strategies
- SLOs, if you use jenkins to manage or deploy you could automatically generate SLOs during the pipeline: Service-Level Objectives — Dynatrace Docs
Hope the above helps!
I would like to use Workflows and upload events through Jenkins
