IP Public for Cluster ActiveGate
Hello all, I have some questions regarding cluster active gate:
- My user have policy that IP public only for DMZ . Is it possible to using cluster active gate but the public IP not directly on it server?
- My user also have some EC2 on AWS but using Dynatrace Managed. Is it possible to set oneagent on that EC2 to send data to CAG while my CAG already being used for RUM?
Thank you.
Hi @agylpradipta
Yes as much as possible it is possible.
You can install a CAG on a machine in the DMZ and do IP address forwarding at the firewall level. For your second question, this architecture is also supported. You indicate in the OA configuration on AWS the bearing of your CAG.
Here you have the whole architecture: Supported connectivity schemes for ActiveGates — Dynatrace Docs
Radek
Thank you @radek_jasinski for the insight
You are welcome:)
