Is it possible for the agent installed on a server to coexist with a monitoring tool?
Hi Everyone,
When I’m installing OneAgent on a Host, is it possible to install another monitoring tool (e.g. Bizagi Diagnostics)?
I’m asking because I have an OneAgent installed on a Bizagi Server and When I install the Bizagi Diagnostics Software I get an error. When I uninstall the agent and try again to install the tool, it installs successfully.
Could you give me a reason about this?
Thank you in advance
its possible but not for all the tools, oneagents need instrument the technologies that are monitored, and other tools do the same thing.
When you got a agent coflict you can see in the deployment status the agent that are in conflict
See this page
https://community.dynatrace.com/t5/Open-Q-A/Conflicting-monitoring-agents-temporarily-deactivated/td-p/180687
