In lookup it is possible with a trick, but in this case it ok just to use join to get this effect. I think this query will give you what you need:
fetch spans
| filter dt.system.bucket == "default_spans"
AND matchesValue(entityAttr(dt.entity.kubernetes_cluster, "entity.name"), "cluster_name")
AND NOT (matchesPhrase(endpoint.name, "*liveness*")
or matchesPhrase(endpoint.name, "*health*")
or matchesPhrase(endpoint.name, "*readiness*"))
AND http.response.status_code>399
| fieldsAdd cluster=entityName(dt.entity.kubernetes_cluster)
| fieldsAdd traces = concat("[DT Link](https://{environmentid}.apps.dynatrace.com/ui/apps/dynatrace.distributedtracing/explorer?filter=dt.host_group.id+in+%28",cluster,"%29+AND+k8s.namespace.name+%3D+",k8s.namespace.name,"+AND+k8s.workload.name+%3D+",dt.kubernetes.workload.name,"+AND+endpoint.name+%3D+",endpoint.name,"+AND+http.response.status_code+%3E+399&tf=now-2h%3Bnow)")
| summarize errorcount=count(),
by:{cluster, k8s.namespace.name, dt.kubernetes.workload.name, endpoint.name, http.response.status_code, traces}
| join
[ fetch spans
AND NOT in(dt.kubernetes.workload.name, {"collab-datamart-content-proxy"})
AND isNotNull(http.response.status_code)
| summarize all=count(),
by:{cluster, k8s.namespace.name, dt.kubernetes.workload.name, endpoint.name}
on: {cluster, k8s.namespace.name, dt.kubernetes.workload.name, endpoint.name},
fields: {all}, kind:inner
| fields cluster, k8s.namespace.name, dt.kubernetes.workload.name, endpoint.name,
http.response.status_code, errorcount, 100.0*errorcount/all, traces
In this case subquery will always produce record for record in main query, so it is safe to use inner join.
lookup command allows only single fields to be user, but you can construct a record containing all needed fields to be used for comparison. Important thing is that on both sides fields need to be names the same and in be in same order.
Such query should produce same results:
fetch spans
| fieldsAdd key = record(cluster, k8s.namespace.name, dt.kubernetes.workload.name, endpoint.name)
| lookup
[ fetch spans
], sourceField:key, lookupField:key, fields: {all}
