if we can find consumer service count for queue with DQL also will be available. if anyone knows, please guide me
Hi @Sisapy09 ,
I think you can create a metric event using a metric from confluence or kafka extensiones.
For example, you can create an alert from metric event using this query:
kafka.consumer.successful.authentication.total.count
In DQL, you could use this metric in Anomaly Detector:
fetch events
| filter matchesValue(event.kind, âDAVIS_EVENTâ)
| filter matchesValue(event.type, âAVAILABILITY_EVENTâ)
| filter matchesValue(event.status, âACTIVEâ)
| limit 20
Hope it helps.
Elena.
i am looking for consumer service count on IBM MQ queues, not related Kafka consumers
Hi @Sisapy09 ,
âibmmq.queue.open_input_handlesâ is the metric you are looking for. You can use this metric in a query in âadvance modeâ of Data explorer or in DQL for dashboards.
And for alerts, use the metric with desired threshold value.
For Example
IPPROCS eq 0 for 5 mins.
