Hi ,
I am working on SRG . Creating one guardian having objectives at application level like ,
1. Application / Service Response time
2.Service Success Rate %
Also looking for container level metrics, Does Dynatrace grail support below metrics
1. Containers: CPU usage, % of limit
2.Containers: Memory - out of memory kills
3. Containers: Memory usage, % of limit
Please help m eon this.
Heramb
You can create objectives based on DQL and/or SLOs.
In your case, the better fit will be create with SLOs. You first create the SLO for the levels you need, then use them as objectives in SRG.
Service/Application metrics are not yet in Grail, so not able to DQL them.
Kubernetes metrics are also not there, but at least, we have an ETA:
Planned for January 2024: New Kubernetes metrics will be available to DPS-enabled customers with the launch of the new Kubernetes app. The new metrics are subject to a new licensing model, as distinct from the current full-stack host units model.
Also, for K8S, check if the templates does fit your needs meanwhile: Create a Site Reliability guardian — Dynatrace Docs
Is there a plan for SLO metrics to become available in grail? This is a meaningful reporting context for creating organization level reports which aggregate SLOs based on divisions/application teams in order to build executive application health and error budget reporting across different leaders/teams. Presenting roll ups of SLOs is very important to product owners and division leaders.
The SLO (Service) metrics are available in grail already.
You can check all available metrics here: Built-in Metrics on Grail — Dynatrace Docs
I dont see SLO or service level objective on that page.
