Is it possible to hide SQL requests
I’ve only been using Dynatrace SAAS for a short time.
I would like to know if it is possible to hide SQL queries (column names and table names in particular) in the Databases statements or purepath part for example.
Even if I am aware that it loses its essence.
Thank you
I suppose that is all you can use:
There are limits in such operations. So as you can se there are some options for masking thigs automatically. But you can’t control it. There are as well options for changing request names inside services (will not affect database calls) but still you will see full URL inside purepath details).
