Is it possible to make a request as key request, using API instead of normal GUI way?
I don’t swe aby endpoint that would allow such function.
Now it is possible , with Settings API - POST an object
In order to help you to use it you can go to the service --> settings --> key requests part and click the …
From the menu pick the API entry
And there you will find the right use of this end point
HTH
Yos
