Is it possible?
Policy boundaries:
Is it possible?
Policy boundaries:
Hi @panumjp ,
I think you can use these calls to policy boundaries:
To get this, go to Account Manager > Identity & access management > OAuth clients. And click on “Account Managment API”
The API calls you need are in “Policy Managment” section.
Hope it helps.
Elena.
Looks like boundary APIs are not yet documented here: Policy management API — Dynatrace Docs
I was able to see boundaries in binding using API, but I was not able to modify boundaries of existing binding.
Do you know is that possible?
Hi @panumjp
I think you have to use this one to update a policy that already exists:
Hope it helps.
Elena.
I think that API is for updating and creating new boundaries. For me (dynatrace newbie) most logical place to set boundaries would be “/iam/v1/repo/{levelType}/{levelId}/bindings/groups/{groupUuid}” API, but who knows ![]()
This would be a great Product Idea. Can I suggest you to create a new one?
https://community.dynatrace.com/t5/Product-ideas/idb-p/DynatraceProductIdeas
