Anyone ever run into the error “Configuration error(Extension doesn’t exist on given host)”, in spite of the presence of custom.remote.python.thirdparty_ping in the ../remotepluginmodule/plugin_deployment directory on the ActiveGate selected on the Settings >> Monitoring >> Monitored technologies >> Ping configuration page?
It’s usually one of three things (in order of commonality):
1. The package was unzipped incorrectly in the plugin_deployment folder, causing a nested folder structure.
2. The dtuserag (for Linux) does not have access to the files.
3. Another extension on the same ActiveGate has a conflicting dependency. This can be seen in the remote plugin agent log. Splitting it up over two AG’s is the easiest fix.
Mike
You may wish to add dist-info folder conflicts to that list. Once they were removed, the issue I was seeing went away.
