There is cost applicable for every features of Dynatrace based on usage(
e.g. 1. Digital Experience Monitoring - >RUM → Per Session / Per Session replay capture).
2.Automation - Automation Workflow → Per workflow / hour s
Is it possible to Turn on/ Off an feature if its usage goes beyond threshold???
Here end goal is to save cost when DT’s features is not use
No. But alternatively, you can disable/enable the features when not in use manually.
Or set the % of data capture to control the cost effectively.
