Is OkHttp3 supported for mobile UEM (Android)?
We are trying to use auto-instrumentation to instrument the Android UEM. They use OkHttp3 to make calls to the internal servers where OneAgent is installed, the auto-instrumentations seems it worked well but the server is not getting any data and we already instrumented the IOS monitoring and is working well and we are getting data from IOS but not for Android.
Hey Alejandro,
Yes, the Android auto-instrumentor supports the OkHttp3 library since the 7.0 version.
If you don’t get any Android monitoring data, then it is very likely that the agent was not able to connect to the PSG.
