is there a way for Admin to view every dashboard created by every user
is there a way for admins to access to access every dashboard created by every user or access dashboard with out asking them to share.. we usually got these requests like something not working in our dashboards, so we have to ask them to share everytime
did you think about using the API for managing dashboards?
Thorsten
As Thorsten said, there is option using api, where you can list all created dashboards, using GUI there is no such option so far.
The only method I know about is through the API. I think however full blown Dynatrace administrators should have this ability right from the GUI.
Hi Ainash
my best practice as follow:
as admin i will export via Configuration API interface list of all dashboard create by user or i ask dashboard id.
i find the user/dashboard to check and i will import (becoming owner) .. remouve owner id and dashboard id from script (done ..i’ve it and i can check it and give back support without asking to share) .
Configuration API --> Dashboard --> /dashboardsCreates
Real Admin need is to “see from interface user dashboard to support user and take over it when needed” to manage grant on it and/or fix.
my use case:
UAT and Production
- i have to export / import every time to allign environment
- 80% of my user are external consultant and go away after projects
- so i’ve to “take over” dashboard loosing every time list of users that have access to it .. after export insert again (if i’m lucky and i know how they are) this .. until you will release ldap group management.
I hope you will release asap as request from all cluster admin in this forum:
- an easy “see all user tenant dashboard” like you have as Dynatrace support … with the power to see and takeover dashboard to support users.
- Ldap group management and tagging for manage dashboard “folder” via Tag like in other section of the tool.
For Enterprice company with large number of users manage via api dashboard is a challenge and “time consuming”
will be appreciated by all admin that opened several RFE on this topic
note: import did not work always well .. i just open a case to support team :slightly_smiling_face:
M.
You can check out our Dashboards API, where you can list all dashboards of your Dynatrace environment, regardless of access rights in the UI:
Dashboards API - GET all dashboards - for Dashboards Classic
API for Dashboards and Notebooks - for Dashboards App
Also, you can check out the documentation article on sharing dashboards:
Share Dynatrace dashboards - for Dashboards Classic
where are instructions on how to configure global dashboard sharing settings.
Hope that helps!
Does this list new dashboards as well?
Hi @asant257,
Here is the link to the documentation with the API call for listing all accessible dashboards for the Dashboard App in the latest Dynatrace:
https://environment/platform/document/v1/documents?filter=type='dashboard'
I’ve also updated the answer above for all the other users looking for it. Thanks for the heads-up!
IMO admins need a simple way to get full access to all dashboards via the UI without involving owners or having to go through the API.
There are already multiple open RFEs asking for this e.g.
Admin access for New Dashboard App - Dynatrace Community
Dynatrace admins allowed to access all documents - Dynatrace Community
View all Gen3 Dashboards - Dynatrace Community
so true , as admins we should be able to see all the dashboards!
done => please see What's new in Dynatrace SaaS version 1.328 — Dynatrace Docs . Sorry we never released an app version 1.328 but went straight into 1.329 and now 1.330 due to the christmas freeze but its already available in production!
I’m a bit surprised that managed dynatrace is not applied the same implementation as saas solution did.
