Is there any way to color code slack notification.
In Hipchat integration open problem notification use be in red and closed in green, by any mean is there any option to do same in slack?
Hi Aamir,
Unfortunately, this is not currently possible.
Checking if this has some chance to get updated, so we can easily see when a slack message is from a open or closed problem…
Thanks.
By any chance is this feature made available in Dynatrace ? this would give a quick and clear visibility of the alerts
You could make use of Dynatrace workflows for this features.
We have a workflow integration called - Slack for Workflows.
Your event trigger would be on event creation, which then you can run a DQL query that collects problems that have been: CREATED, RESOLVED and CLOSED.
For each of these, in the body of the slack message, you can make use of the slack formatting through the API push to your slack channel. Emojis and what not
Hope this helps
Lawrence
There is also a hands-on video of this integration available on YouTube:
