Hi everyone!I’m encountering an issue with the appsettings schema (described here).In my configuration, I’ve declared a text variable and set minLength to 0 to allow the field to be null, empty, or equal to “”. I also add nullable: true without success.
you should try to set “nullable” to “false” (and provide “default” value in this case). Then “minLength” of “0” should be considered by the framework. The thing is that for “nullable” fields minimum “minLength” is always “1”, meaning in your case where it’s true it will create an error.
