Issue with GCP logging inject to Dynatrace
Hi Everyone,
Any suggestion to fix the below Issue.
Logs were not getting injected to Dynatrace.
Followed the step to configure in the GCP Cloud, Dynatrace monitoring & logging into Existing GKE Standard Cluster.
Flow is Logs(Default GCS bucket) --> Log Router sink --> Pub/sub --> Dynatrace Monyeting log (container) --> Inject to Dynatrace.
command ran : kubectl -n dynatrace-gcp-monitor logs -l app=dynatrace-gcp-monitor -c dynatrace-gcp-monitor-logs
2024-05-17 16:29:39.319115 [Process-0][Worker-1] Skipping pushing logs - no logs to push
2024-05-17 16:29:39.396180 [Process-0][Worker-4] Skipping pushing logs - no logs to push
2024-05-17 16:29:39.399226 [Process-0][Worker-0] Skipping pushing logs - no logs to push
2024-05-17 16:29:39.499611 [Process-0][Worker-3] Skipping pushing logs - no logs to push
2024-05-17 16:29:39.527187 [Process-0][Worker-2] Skipping pushing logs - no logs to push
The error states there are no logs to push, can you confirm that there are indeed logs ready to push?
