Hi
I have tried setting the kubernet monitoring as per document .. but i have been always getting TLS issue for self signed certificate .. or even invalid token sometime ..
1. Using Keytool - imported the certificate in existing trusted.jks file with passwod trusted
2. Adding entry in custom.property file also .
3. Restarted all gateway/agent ..
4. Enter the kubernet URL and token but getting TLS or invalid token issues
Also tried with no certificate options also.. then getting same TLS issue ..
Note : Agent/gateway installed on same rancher-kubernet cluster node … my server is on different node.
I am able to see docker images due to agent on that node … but API/Token failing for TLS.
Q: What is right step for connection…
Q. Is it fine to use existing trsuted.jks ( i have tried even with jks file)
Q. Will not this work with self signed certificate
Q. Is certificate need to be generated on a node where agent and activeagete installed ?
