Ivanti integration
Hi All,
Can I integrate Dynatrace with Ivanti ITSM?
You can send notifications via Webhooks.
Best regards
Is by webhooks will open a ticket automatically, and please provide me how to integrate.
Hi, @Mohamed_Maarek
Dynatrace will send a payload to Ivanti. Do you have some API in Ivanti to receive information?
Best regards
You can use the webhook integration as @AntonPineiro mentioned. in case you need a tailored way for the integration, you can check Zigiwave integrations. they provide a connector between Dynatrace and Ivanti.
Islam
Hi @Mohamed_Maarek,
Did the information provided by @Islam_Zedan and @AntonPineiro help you?
