Below is the Java class which i have written to call a usersession api , but i get 400 as response. Any help here could be appreciated. Is it issue with setting api header ? The same url is working in post man client.
package com.spx.dyntrace;
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStreamReader;
import java.net.HttpURLConnection;
import java.net.MalformedURLException;
import java.net.URL;
import java.util.Base64;
public class Post {
// http://localhost:8080/RESTfulExample/json/product/get
public static void main(String[] args) {
try {
String API_KEY= “YOUR KEY”;
URL url = new URL(“https://YYYYYY.live.dynatrace.com/api/v1/userSessionQueryLanguage/table?query=SELECT endTime as time, userSessionId , SUM((useraction.visuallyCompleteTime)) AS 'Server Processing Time’FROM usersession WHERE (userId=‘Full Quote User 1’ OR internalUserId=‘Full Quote User’ or userId=‘Full Quote User 2’ or userId=‘Full Quote User 3’ or userId=\“Full Quote User\”) and userActionCount > 25 and userActionCount <50 GROUP BY endTime ,userSessionId&startTimestamp=1586905282288”);
HttpURLConnection conn = (HttpURLConnection) url.openConnection();
conn.setRequestMethod(“GET”);
conn.setRequestProperty(“Accept”, “application/json”);
//conn.addRequestProperty(“Authorization”, basicAuth);
conn.setRequestProperty(“Authorization”, “Api-Token=YYYYYYYY”);
conn.setDoInput(true);
if (conn.getResponseCode() != 200) {
throw new RuntimeException("Failed : HTTP error code : "
+ conn.getResponseCode());
BufferedReader br = new BufferedReader(new InputStreamReader(
(conn.getInputStream())));
String output;
System.out.println(“Output from Server … \n”);
while ((output = br.readLine()) != null) {
System.out.println(output);
conn.disconnect();
} catch (MalformedURLException e) {
e.printStackTrace();
} catch (IOException e) {
