I have been making some tests to get an efficient use of resources on AGs that I have that mainly do extensions v2. I have looked especially at memory, so EEC can have more memory available. I have made some changes, including:
Changed the performance profile of AGs to “High limits”. I didn’t change to “Dedicated limits” as I have extensions v1 also running, and documentation says we should not do it in these circumstances. But still curious if it can be done?
About Extensions — Dynatrace Docs -
Restricted AG functionality according to Dedicated performance profile configuration — Dynatrace Docs
Not quite sure of the impact, as a lot of jars for these functionalities are still being loaded into the AG process. -
I entered the lines below in launcheruserconfig.conf, according to Configuration properties and parameters of ActiveGate — Dynatrace Docs
They really seem to make a little difference in memory consumption.
Configuration properties and parameters of ActiveGate — Dynatrace Docs-java.xmx.absolute_part=2000
-java.xmx.relative_part=0
Now, looking at the dsfm metrics for the ActiveGates, especially dsfm:active_gate.jvm.heap_memory_used, I have noticed that it doesn’t go above 700 MB, and normally is much lower. Which makes me wonder if the java.xmx.absolute_part can’t be defined lower than 2000?
