Jira for workflows connection settings not allowing URL (max 50chars...)
I’m setting up a Jira connection at my customer, and am running into an issue with the length of the webhookurl.
I can create a “fake” connection definition when I use a short URL, but as soon as I paste the atlassian webhook URL that is generated for my project, I get an error indicating: “Name has to be between 1 and 50 characters long”.
At first I thought this was just a UI bug, but also the API returns this message as soon as the URL exceeds 50 chars.
Is there any way currently I can push my definition without getting this check/error? Because I cannot change the webhook URL delivered by Atlassian-Jira.
Thanks!
Sjoerd
PS. the fact that the message is “Name…” instead of “URL…” makes me wonder if it is not just a very simple bug in assigning checkrules to api fields
...<br>...<br>"error": {<br>  "code": 400,<br>  "message": "Constraints violated.",<br>  "constraintViolations": [<br>  {<br>    "path": "app:dynatrace.jira:connection/0/url",<br>    "message": "Name has to be between 1 and 50 characters long",<br>    "parameterLocation": "PAYLOAD_BODY",<br>    "location": null<br>  }<br>  ]<br>},<br>....<br>....
Jira for Workflows does not support Webhook URLs. The only supported authentication methods are: Basic Authentication, Personal Access Token, Jira API Token.
All three of those require an URL that looks like this: https://{environment}.atlassian.net (for SaaS) or https://jira.somehost.com (for Jira Data Center / on-prem).
