Hi all,
I’m integrating Jira to send problem notifications from Dynatrace and I’m facing the following error:
"Jira test failed
Reason: Invalid HTTP status code
HTTP Response Code: 401 - Unauthorized
HTTP Response Body:
{“errorMessages”:[“You do not have permission to create issues in this project.”],“errors”:{},“reasons”:[]}"
Im using Jira Cloud and the step I followed to link both accounts are:
- using the Jira URL: https:// FFFFFFFFFFFFFFFFF.atlassian.net
- created an API token with required scopes and used it along with the environment ID on this plugin (scope Access problem and event feed, metrics, and topology (API v1), Read synthetic monitors, locations, and nodes (API v1), Read entities (API v2))
- created an Atlassian API token and used it on dynatrace
- used my admin user to connect
- used the issue type:
I’m using a trial account, how can I fix the error?
