Outbound message posting issue with x-dynatrace header. Java JMS is not supporting any special characters in header key. How to disable the “x-dynatrace” or any other way to make it run.
error.txt (692 Bytes)
Hello @Zishnu
Dynatrace recommendations to configure the attached headers through the Firewall && F5 to ensure traffic is passing as expected.
For Mobile RUM, if you’re exposing the same issue, should configure the attached 5 headers as well.
Ensure the OA Features are enabled, and required actions have been executed.
BR,
Peter.
