JS Error | Cannot read properties of undefined (reading 'key') - while creating Select
Hi there,
I’m trying to create a basic select using the documentation page available on the developer portal.
For example:
While executing this, the following error is shown:
Is also tried, without any success..
Does anybody also encountered this issue. If so: where is my error?
Kind regards,
Michiel
Hi @michiel_otten ,
this issue should be fixed in the latest version 0.99.3 of @dynatrace/strato-components-preview.
Are you already on this version? If not then please update your dependencies by executing npm run update.
Thanks @stefan_eggersto , this worked for me!
Another question is: where could I’ve found the solution myself? Is there some sort of changelog?
You can find a changelog at https://developer.dynatrace.com/whats-new/release-notes/design-system-preview-changelog, however this particular issue was unfortunately not clearly described.
