| Hi Team,We want to show a metric "JVM memory heap used percentage" in dashboard. I could see " JVM runtime free memory" and "JVM runtime total memory" metrics are already available in Dynatrace. Can you please suggest if we can use a simple formula to get JVM memory heap used percentage.Regards,Rosyland |
I dont see the ability to do that, I would recommend tossing in a RFE requesting that functionality and hopefully it will be built into a future release!
The JVM Heap Used percentage can be achieved in Data Explorer.
Hello @Shirai
I require your help in determining the percentage of memory pool utilized for the following:
((builtin:tech.jvm.memory.pool.committed:filter(and(or(in("dt.entity.process_group_instance",entitySelector("type(process_group_instance),softwareTechnologies(~"IBM_INTEGRATION_BUS~")"))))):splitBy("dt.entity.process_group_instance"):max:sort(value(max,descending))) / (builtin:tech.jvm.memory.pool.used:filter(and(or(in("dt.entity.process_group_instance",entitySelector("type(process_group_instance),softwareTechnologies(~"IBM_INTEGRATION_BUS~")"))))):splitBy("dt.entity.process_group_instance"):max:sort(value(max,descending)))) * (100)
Babar
