JVM metrics for Pods
Hi Team,
Could anyone please suggest how we can achieve pod-level monitoring in Dynatrace, including key metrics such as:
  • Throughput
  • RPM
  • JVM metrics
  • Other critical indicators
Currently, I am unable to find JVM metrics for the pods. If anyone has experience or knows the steps to configure this, please share your guidance.
Thanks in advance!
For Kubernetes entities (pod, workload, etc.), you need to enable Kubernetes platform.
Best regards
In Dynatrace, JVM metrics will be associated with the process entity, not the pod directly (i.e. you will find them in the  Infrastructure and Operations app)
To be more precise these metrics are pushed in by a OneAgent running alongside your process not just with the Kubernetes API integration. Here is a guide how to deploy the Dynatrace Operator to achieve this level of monitoring: Get started with Kubernetes platform monitoring + Full-Stack observability — Dynatrace Docs
Sample from a Pod with link to process
And the JVM metrics on the process entity
