Kick Start for Hybris Dynatrace Installation
I am having my Hybris application [1905 Version] installed in Linux. How Can I start integration with Dynatrace so that I can able to see Monitoring /CPU Utilization Logs in Dynatrace.
Are we having any steps that I can follow?
Appreciate any help!
You should be able to install the oneAgent on the host and gain all you need. If you go to deploy dynatrace> Linux copy the commands and run them on the host, you will have the OneAgent installed and monitoring your host and app
