1. Can we set up Kiosk mode to display the dashboard in Dynatrace Saas? I know the Kiosk mode is available in AppMon, but could not find any information on how to set it up in Saas.
2. Does Saas time-out by default? Can we set up no time-out?
1. There is not a “kiosk mode” for Dynatrace, but there is the possibility. Use a browser plugin (such as Rotisserie URL Rotator, for Google Chrome, and populate the dashboard URLs in there.
2. There is a timeout there yes. You can’t turn it off, but you can try to keep the session active to prevent logout using tamper/grease monkey scripts to simulate some interaction on the page
How does one view log entries from the log query table dashlet in an anonymously shared dashboard link? We have a very special requirement to display log entries on a big screen internally. The log dashlets are the only ones not visible when shared anonymously.
