I want to integrate the kubernetes AKS cluster with dynatrace. I have done for one cluster as per below documentation.
But the kubernetes url and token changes every-time when the do the deployment. I there any way to integrate the kubernetes using curl command?
so i can automate the process to run the command with the latest urls on the dynatrace servers to integrate.
Mayana Khan
