Hi , I have deployed one application in Kubernets and after that One agent has been (Full stack) deployed in Kubernets as well. Still I couldn’t see the application in dynatrace UI.
I have checked the Kubernets services were running fine in DT
And One agent is deployed in Pods where that deployed application is running.
Help me to resolve this and how I could check and get Application visibility under UI.
I understand you can see pods, containers and services in Dynatrace, right?
And you are missing Real User Monitoring? Is that?
Best regards
yes, same issue. In documentation it is stating that after One Agent deployement we could see the App directly. but I cant see the App (RUM details ) even the Application name is not visible.
Do you have default web application enabled in your tenant? You can check those docs:
Best regards
