Oracle DB extension collects data for Backup jobs and creates lot of entities of type Oracle DB Backup Job. Which is nice until you hit this error and backup jobs stops showing in oracle instance screens (and anywhere else).
I’m not able to find any documentation related to this issue (link “learn more” is not working anymore;) ). So i cannot find what is the limit and how to limit/delete created entities.
If I remember correctly the limit is 100.000 entities of a single type. Either you have quite a few backup jobs, or there is something (semi) unique in them which makes the number of entities explode. I’d go with a support ticket so we can look into it further if I were you.
This is Managed and i have fresh info from support:
there is limit for entities (100k in this env) which was hit with data from 30 Oracle instances (backup job featureset enabled) after 2 and half month. Another hidden info is about clean up job, that takes care about such short term entities but in this env it’s set to 180 days. So either limit need to be extended or job interval should be shortened.
Any of that will be easier, if Oracle Database extension mentioned this limitations in documentation.
What is important is the ID though, and the ID is built up using the following dimensions:
idPattern: sql_sql-oracle_{device}_{device}_{session_recid}_{session_stamp}
I’ve asked the owner of the extension to have a look at it, and will point support to this thread.
I got confirmation from R&D via support, that extension works as designed, but unfortunately limits are hit. Solution is planned and will be sometimes released as update of Oracle DB extension. Unfortunately, according to support: “Regarding the fix, please track the release notes. It will be a breaking change, but currently, it’s planned with low priority, so there is no ETA”.
I got temporary fix via support, maintenance job running every 180d, was changed to 30d. So i got working entities for DB Backup Jobs again.
