List of Terminology for Synthetic Monitoring
Summary
This glossary defines key Dynatrace Synthetic Monitoring terms, including Browser and HTTP monitors, Synthetic locations, ActiveGates, and core execution components.
Terminology
ActiveGate (AG)
Required to run a private Synthetic location.
Browser Monitor
A Synthetic test that runs in a Chrome browser to simulate a user’s browser journey. It uses the Dynatrace JS Agent in order to collect the same timings that we use in RUM.
Clickpath
This is a Browser monitor that consists of one or more synthetic events. These events create are executed as a single browser session/ user journey.
Cluster ActiveGate (CAG)
This is required by for Managed deployments in order for the Dynatrace Cluster to receive Synthetic test results back from the public locations.
DEM units:
Licensing unit that is consumed when running Synthetic HTTP and Browser Monitors. Calculate DEM Consumption
Dynatrace Synthetic Recorder
The Dynatrace Chrome extension that is used to record a clickpath for a Browser Monitor or playback it locally.
Synthetic Event
A single operation within a clickpath, eg clicking on a button.
HTTP Monitor
This synthetic test allows you to make HTTP requests
Multidimensional Analysis (MDA)
Screen which allows you to analyze the individual runs of a synthetic test.
NAM
Network Availability Monitor. These synthetic tests allow you to make Synthetic ICMP, TCP or DNS requests.
Private Synthetic Location
These locations are hosted on the customers own infrastructure. They require a Cluster or Environment ActiveGate with the Synthetic module enabled to be able to run the synthetic tests. You can also create containerized private locations.
Public Location
These locations are hosted by Dynatrace on our cloud infrastructure across the globe to run the customer’s synthetic tests.
Synthetic Action
An event within a synthetic browser that triggers a web request that includes a page load, navigation event, or action that triggers an XHR or Fetch request. This consumes DEM Units.
Virtual User Controller (VUC)
This is the controller on a Synthetic location that will receives the tests to run and launch the VUPs to run them.
Virtual User Player (VUP)
This is the Synthetic player on a location, which consists of an instance of Chrome which runs the Synthetic tests and a Chrome extension which communicates with the VUC. There can be many VUP running simultaneously per location.
What’s Next
You can add a comment to the article to ask for explanations of further Dynatrace Synthetic terms.
Related reading
:open_book:  Synthetic Troubleshooting Map
:open_book:  Getting Started with Synthetic Monitoring
This is great, thanks @xu_guo
