Litmus Chaos Experiment Dynatrace Annotation
Is there a way to annotate chaos experiment with Litmus to be viewed within Dynatrace.
The same way we have Gremlin webhook “indicating current Gremlin CPU Attack”
Am currently using Litmus, please share detailed way to do this and if possible relevant documentation
Interesting ask. Id assume Dynatrace would see the experiment as regular usage but at a higher frequency, unless you passed some info event of some sort to the entities in which you are targeting for testing. Once that is present you’d have more functionality in terms of tagging, grouping and reporting.
