I’m trying to see if there is a way I can create a problem utilising a long log entry. I have not worked out if it is better to have one long log content entry with multiple lines, or multiple log entries and consolidate those to one event/problem.
I am using the OneAgent log ingest api and have the flexibility (somewhat) to post either a log entry per line into dynatrace. Or concatenate lines into one content entry.
I’d then like to extract that as an event which will ultimately be given to ServiceNow which has the concept of a short description “I have a problem” and a long description - the mulitple log lines.
Am I barking up the wrong tree?
