Log Monitoring for extension only
Hello Team, is it possible to turn on log monitoring for a specific extension rather than in the whole environment?
Dynatrace offers the ability to :
Hi Jarin, yes! it is possible, however it depends on which log monitoring classic version you are running on your tenant. That will determine the ability for you to configure your extension as your log source.
