This is a question on the usage of the LogDiskBufferPath option in the custom.paramters of the ActiveGate.
- How is it used?
- Do you advise us to use a separate FS to the ActiveGates and JavaDUmp ones? Which size?
Ref: Configuration properties and parameters of ActiveGate — Dynatrace Docs
Regards
