Logs Troubleshooting Map
A decision-tree guide for troubleshooting log ingestion, source health, delays, volume, parsing, correlation, and alerting issues in Dynatrace.
First time here? Find your symptom in the table below and jump directly to the right section. No need to read top to bottom.
How to use this map
Find your symptom
What you are seeing Go to
Logs that worked before have suddenly stopped Step 1A
A source has never appeared in Dynatrace Step 1B
A source is visible but not ingesting records Step 1C
Log Monitoring is enabled but still no logs Step 1D
One ingestion method is affected (API, K8s, Azure, etc.) Step 2
Logs arrive late or only partially Step 3
Log volume increased or decreased unexpectedly Step 4
Logs are visible but content, attributes, or timestamps are wrong Step 5
A log metric or event is not triggering Step 6
Trace link missing from a log record Step 7
Dynatrace Managed cluster shows a log warning Step 8
Step 1A  Logs that previously worked have stopped
Start here first: Open Dashboards → Log module self-monitoring and check the Currently active issues panel. The platform may have already identified the cause via a self-monitoring event (SFM event). Act on that before changing any configuration.
SFM events are available at OneAgent 1.339+ / SaaS 1.340+. Earlier versions require opt-in via the Settings API see Monitor log source health with SFM events.
My logs went silent  where do I start?
Covers: OneAgent Log Module unhealthy · Kubernetes Log Module unhealthy · ActiveGate health issue · SFM event reference · source coverage check · module restart behaviour
Step 1B  Source has never appeared in Dynatrace
Troubleshooting missing logs in Log module
Covers: path and permission checks · security rules · custom source configuration · SFM log_source.status query · global Log Monitoring toggle · app log content access flag
Step 1C  Source is visible but not ingesting records
Log source not detected or not ingested: Troubleshoot source discovery and ingest-rule coverage
Covers: Sources tab · ingest-rule coverage · matcher vs source name · active and inherited rule review · unique-record validation
Step 1D  Log Monitoring is enabled but logs are still missing
Work through these in order:
Situation Article
Initial setup  never produced records on this host Enable Log Visibility in Dynatrace
Enabled and monitored but records aren’t visible Why are logs still missing after enabling Log Monitoring?
Security rules may be blocking the path Troubleshooting Missing Log Files Due to OneAgent Log Monitoring Security Rules
Server-side prerequisites (Logs Classic) What might prevent logs from appearing on the server?
F5 Distributed Cloud WAAP intercepting communication Logs Not Being Ingested Due to F5 Distributed Cloud WAAP
Step 2  One ingestion method is affected
Select the ingestion method:
Step 3 Logs are delayed or only partially arriving
Situation Article
Records arrive late (including expected ~90s Kubernetes baseline) Troubleshooting log ingest delay in Log module
Ingest endpoint returns HTTP 429 Dynatrace does not ingest logs: HTTP 429
ActiveGate extension buffer or persistence full Logs Not Arriving from ActiveGate Extensions: Log Persistence Full
Multiple sources via one ActiveGate affected Check Ingest components health in Log module self-monitoring dashboard → ActiveGate sizing for Kubernetes
Step 4 Log volume changed unexpectedly
Both volume spikes and drops use the same starting article.
Log volume spiked overnight where is it coming from?
Covers: Top log producers · OpenPipeline self-monitoring metrics · ingest-rule scope review · volume decrease investigation · preventive alerting
Step 5 Logs are visible but incorrect
Symptom Article
JSON stays in content  expected attributes not extracted Troubleshooting JSON parsing in Log module
Multiline records split incorrectly Troubleshooting log boundary detection in Log module
Gaps, duplicates, or missing records after rotation Troubleshooting log rotation issues in Log Module
Content trimmed · attributes missing · timestamp corrected (dt.ingest.warnings present) What do log ingest warnings on my records mean?
Ingest source sends static enrichment attributes missing or wrong Troubleshooting for Ingest sources that send data along static enrichment
Records don’t look right in general Why don’t ingested logs look as expected?
Attribute key case mismatch warning Ingest warning about an attribute-key case mismatch · How to enable the attribute-key mismatch feature
Case-sensitive query warning (Logs Classic) Case-sensitive query warning in Logs Classic
Records out of order or under the wrong timestamp Timestamps in Logs with OneAgent 1.313+
High resource use from log enrichment component High Resource Overhead from the Log Enrichment Component
Quick check before parsing investigation: Run fetch logs | filter isNotNull(dt.ingest.warnings) | summarize count(), by:{dt.ingest.warnings, log.source} | limit 100  if warnings are present, start with the ingest warnings article, not the parsing article.
Step 6 Log metric or event is not triggering
Situation Article
Log-based metric shows no data Dynatrace Log Monitoring: Metric Shows No Data
Problem opens against the wrong entity How to Change Impacted Entity for a Log-Based Event or Problem
Step 7  Trace link missing from a log record
Why I Can’t See Traces in Log View Page
Step 8  Dynatrace Managed cluster warnings
Warning message Article
Log ingest queue is full Log Ingest Queue Is Full: Dynatrace Managed
Ingested log data is trimmed Ingested Log Data Is Trimmed: Dynatrace Managed
Before contacting Support
Collect the following before opening a ticket:
  • When the issue started and the timezone used
  • Affected host, host group, cluster, namespace, workload, or source path
  • Screenshot from the Log module self-monitoring dashboard  Currently active issues panel
  • SFM event type, severity, and any source or entity context
  • Source coverage state from the Sources tab
  • Active and inherited ingest rules with matchers and scopes
  • Sanitised sample record and result of a unique-record search
  • dt.ingest.warnings DQL result (if records are visible but incorrect)
  • Recent changes  application, permissions, deployment, or Dynatrace configuration
  • OneAgent, ActiveGate, Operator, or collector version
Do not include credentials, access tokens, personal data, or unmasked log content.
Further Reading
Hi, nice summary, thank you! :money_mouth_face:
