Logs viewer syntax
Hi Team ,
In the Dynatrace LOGS section I am trying to filter according an  integer parameter (elapse time)  .
what should be the syntax if I want to see results for greater/lower  than etc.  ?
Thanks in advanced
Hi @idand,
Based on the documentation there is not such expression “>”. Only = and != are allowed. :frowning:
Log viewer (Logs Classic) | Dynatrace Docs
I hope it helps.
Best regards,
Mizső
I think it can be done using log processing functions powered by Grail.
Best regards
