Logstash Json logfiles vs Dynatrace
When you implement logstash, Dynatrace is unable to read the replaced logfile, the new format is son,
Is it the one or the other?
KR Henk
I don’t understand your case. You are monitoring logstash and you want read logs that are created by this technology or you want to export some data to logstash?
Hi Sebastian,
my mistake: customer lets tomcat log in json format, I think to make live easy for logtash. So my question should have been, is dynatrace capable of reading json logs. And I think the answer will be no, or not yet?
KR Henk
according to documentation:
JSON Formats are supported as well.
Henk,
Check out the timestamp requirements on this page and make sure those are met:
HTH,
dave
The json log contains a timestamp, is not marked as having an invalide date format but still,
Your search didn’t return any log matches for the selected time frame
So could the conclusion be that the format is fine, but Dynatrace can not handle the invalide content of the date field?
See a example log line:
{“clientip”:“xx.xx.xx.xxx”,“timestamp”:“[17/Jun/2019:00:00:00 +0200]”,“request”:“GET /xxxxxxx/api/internal/v1/xxxxxxxxxxxxxx=xxxxxxxx=xxxxxxxxxxxxx=true HTTP/1.1”,“urlpath”:“/xxxxxx/api/internal/v1/xxxxxxxx”,“urlquery”:“?xxxxxxxxx=xxxxxxx&xxxxxxxxxxx=XXXXXX&xxxxxxx=true”,“protocol”:“HTTP/1.1”,“method”:“GET”,“port”:8080,“status”:200,“bytes”:12,“duration”:57,"xxxxxxxxx:“xxxxxxxxxxxxxxxxx”,“xforwardedFor”:“xx.xx.xx.xx”}
In link that I’ve provided is info that in JSON there is only one timestamp format that can be used (at least for now). Your is different so yes, log is ok but without proper detection of date you cannot search it.
