we have an AWS infrastructure with multiple EC2 instances, S3 buckets, and Lambda functions.
Can someone help me to share the best fit basic architectural diagram for AWS integration?
Suresh
Suresh
hi surisetti
you are refering to this architecture ?
if you need something more specific you can use the librery for partners
there you will find some architectures for dynatrace saas, oneagent, manage maybe should be usefull.
or if you have oneagents on your enviroment you will see the topology on smartscape
this topology its very usefull when you are doing some more detailed architecture diagrams in (draw.io, miro, lucidcharts)
regards
