makeTimeseries in DQL with lookupField
How to create makeTimeseries  in this DQL to be able to create alert from it :
timeseries { uptime = avg(com.dynatrace.extension.network_device.sysuptime), by: { `dt.entity.network:device` }, interval:1m }
| fieldsAdd status = if(isNotNull(uptime[-5]), 0, else: 1)| fieldsRename device=`dt.entity.network:device`
| lookup [
fetch `dt.entity.network:device`
| expand tags
], lookupField:id, sourceField:device
| filter isNotNull(lookup.id)
| fields timeframe, interval, status, device, lookup.tags
To create a DQL-based custom alert, the query must output a numeric timeseries column array.
I think that in your case status is currently computed not as a array because you use uptime[-5].
Try this:
timeseries {
  interval: 1m
| fieldsAdd status = if(isNotNull(uptime[]), 0, else: 1)
| fieldsRename device = `dt.entity.network:device`
| lookup [
    | expand tags
  ], lookupField: id, sourceField: device
status as a 0/1 timeseries.
Then in alert select status
Thanks a lot it works however I need to exclude last value from array ‘uptime’ because in each case is “null” so that my alert will be useless.
Yeah, you can drop the last (incomplete) bucket using to:-1m, but in this case you need to use from too.
This is what I mean:
timeseries {
  interval: 1m,
  to: -1m
| lookup [
    | expand tags
thanks to that you will drop the trailing null bucket
In documentation I found that you can use arrayLast(uptime) - it returns the last non-null element
Array functions
thanks, that’s perfect solution !
