Hi guys,
The customer is connected to local LDAP for the user repository and asks to use SSO with OpenID on Azure.
Strand Login working perfectly.
SSO Logins are failing and we see it from Events.
Where can we see the errors in Dynatrace or Azure to understand why the SSO logins are failing?
BTW Should we remove the group query from the local LDAP and use it from OpenID on Azure?
Thanks in advance for your inputs here
Yos
