Management Rule - SQl Server running on windows virtual machine
Hi Everyone
We have a Azure VM and on that Sql server is running which we have installed using extention , we’d like to monitor SSISDrive-local service .
As soon as if it gets stop we should have a alert profile trigger, i am creating entity selector to trace teh rquired service and tried many ways however so far didn’t find any solution
e.g.
type(“PROCESS_GROUP_INSTANCE”),entityName.contains(“sqlservr.exe”)
type(“PROCESS_GROUP_INSTANCE”),entityName.contains(“SSISMapDrive”)
type(“PROCESS_GROUP”),entityName.contains(“SSISMapDrive”)
Could you please direct me to create rule  to capture running sql server job on virtual machine host.
Hi @sachinkdy
IMO, You can set availability monitoring on process group setting or to set OS services monitoring for the OS service that runs sqlservr.exe
HTH
Yos
