I added metadata to a process group as recommended in
Tagging is a powerful mechanism. However, to reap its benefits, tagging should be used carefully and in a meaningful way. To guide you towards this end, we provide you with specific recommendations and best practices, which are described below. With...
Now I want to make use of it in a management zone rule.
I fail to do so. I tried: type(process_group_instance),customPgMetadata(“Environment=Level_01”)
Can someone help me with it?
P.S.: my current workaround: I use an automatically applied tag rule to lift the information into a tag which I can use with the management zone rule.
Regards, Olav
I was able to complete this ask. Granted this is set at the host level but can be applied to PG instances via PGs with the following:
My example rule for autotaging:
type(process_group_instance),processType(“NGINX”),customPgMetadata(“[ENVIRONMENT]DOG:CORGI”)
Result:
Manifest:
yaml:
- name: DT_CUSTOM_PROP
value: "DOG=CORGI"
This is response from API (ENV v2) /entities/{entityId}
I have to use this API to create right entityselector. It is really helpful. You need to define only EntityID - from browser -PROCESS_GROUP_INSTANCE-XXXXXXXXX and you will get all properties in JSON.
Hope this helps and good luck.
Alex Romanenkov
Hi @Olav_Wollrab ,
you can also try the following
type(process_group_instance),customPgMetadata([ENVIRONMENT]Level_01)
type(process_group_instance),customPgMetadata([ENVIRONMENT]Level_01:QA)
Gentlemen, thanks to all of you for your valuable input. 🙂
Regards, Olav
